Hi folks
Looking for some help from the team here. I have a Stenner Pump with 15 gallon tank. I’m looking to cover the tank to shield it from direct sun, as I believe the intense heat outside is causing undue degradation of the chlorine (I’m in Phoenix).
Im considering 2 different options to cover the tank (unless someone has a better idea).
1. Using a trash can. Stenner tank would simply be placed inside of s plastic Rubbermaid can. May drill a few ventilation holes in this setup.
2. Using a bbq grill cover. Weber makes a round cover for the classic 22” Weber, which would fit perfectly. Since the cover fits a bit loose, additional ventilation may not be needed.
Im tempted to get the Weber cover since it is a bit more user friendly. I believe the heat wouldn’t build up quite as much also as the cover supposedly “breathes”. My concern though is about flammability. I’ve heard chlorine can become flammable if it comes into contact with certain materials. Is this a concern, or incorrect? Any thoughts or suggestions on covers is appreciated!
