Static shock Desperate need help Semi in ground
fatchoppers
Active member
Apr 5, 2015
25
farmingdale NY
I know this has been covered but every case is a little different. No one believes me ! Every now and then I get a static kind of shock on my finger tip when touching the water with shoes on standing on my deck . The deck is new btw. This happens with the filter off and unplugged. . Seems to happen after I arrive from my hour drive from work and go straight back to the pool after arriving home . It does not happen when I stand in the same spot bare footed or even when the deck is wet.
I will continue further when the experts chime in. But the pool is bonded . I don’t want to shrug it off yet I don’t want to pay a master electrician for nothing.
fatchoppers
Active member
Apr 5, 2015
25
farmingdale NY
Can it be as simple as I am discharging a static shock into the water or is this a sign something wrong. Again everyone is using the pool with no issues. But I do know I feel it now and then
stricsm
1
Alabama
It looks like your deck is a synthetic material. If the shock dissipates when touching the water, then I would say it is a pretty good bet you are simply discharging static electricity accumulated by walking on a dry deck. A wet deck would be less prone to static generation as would going barefoot because there is less friction. If the shock continues after touching the water, then that is another problem altogether.
Tpopz
73
Versailles, Kentucky
Static shocks from composite decking are a known annoyance, especially in dry climates. Would definitely call builder, supplier, manufacturer to see what they recommend. I think there are several “staticides” available, but they need to be reapplied often and are far from an ideal solution.
fatchoppers
Active member
Apr 5, 2015
25
farmingdale NY
Thank you. This is what im hoping .
Coveys
Active member
May 6, 2019
44
Central FL
I posted this earlier on a similar post and thought I’d share since you question is similar.
Bonding or Grounding can do nothing for you. Plastic is a non-conductor and electrical charges cannot move through it.
The static charges you are getting are generated by friction, at the point of contact between your shoe and the deck.
Licensed Electrician
