I currently have a semi-inground pool that was probably installed about 20 years ago. We moved in 9 years ago and have enjoyed it but the deck around it is nearing the need for significant repairs. I'm starting the process of appointments and quotes which based on supply and demand is the wrong time. I've had a pool since childhood and maintained my current pool so I know about owning one. I have plenty of room so I could put in a much larger pool than I can afford. I'm probably looking at holding back on things that I can do later. I'm definitely a function first and appearance second mindset.
Here's my wishlist:
Approximately 18 x 45 - With 45 feet I can swim laps and have my Garmin track distance. Shorter is possible if I swim diagonal.
A fairly large play area
No diving board but I'd like a deep end. It doesn't need to be super deep.
Natural gas heater - We cover the pool at night religiously and it's around 85 degrees most of the summer. We use our current propane heater occasionally but it's pretty old and we now have natural gas so that's a preference.
Pavers surrounding the pool, probably more square footage than I have on the deck now.
Probably Vinyl Liner
No real preference on Filter/pump etc. I've only used DE Filters so that's my baseline. If cartridge works better I'd consider it.
I'd like salt but would consider waiting if it allowed me to get other stuff that's more important.
I'd like automation but also would consider waiting.
I'm very DIY so if there are things I can do that will save money, I will do it.
I've had one company out so far and based on the slope of the property he suggested that the inground pool would probably be similar height to the current pool. It would then need retaining walls around the pool for the pavers. I can add pictures if that needs more explanation.
Any thoughts or suggestions ranging from "go all in and sell a body part to pay for it" to "don't be stupid, wait until the deck falls apart and then fix the deck" would be appreciated. Also any recommendations from other Long Islanders (central Suffolk) on pool builders would also be appreciated.
Here's my wishlist:
