A couple of months ago, I switched over to the TFP method for my swimming pool, and that has gone very well so far. With that behind me, I've decided to try the same with my hot tub. I've got a 2011 Hot Springs Sovereign with a Nature2 cartridge (changed every 6 months) and an ozonator, and the spa company I purchased from had me on this regimen: fill tub, shock with spa guard enhanced spa shock, add Silk Balance. Once a week, 1.5 caps of spa guard enhanced shock and 3oz of Silk Balance. That's it! Actually, this seemed to work pretty well for a few years. After that, the black stuff started growing around the controls and all over the pillows. I think my ozonator had died, and I didn't get it replaced for quite a while. The water never looked cloudy, but I'm sure it had all sorts of issues. I would like to straighten this thing out, and I have a few questions after reading the Nitro post and several other threads.
I just emptied and refilled the tub. I have tested the CH (125) and TA (95) while the water is still in the 70's and heating up. I'm going to use the acid / aeration method to lower the TA to around 50. I haven't tested the PH yet, because I believe I read that the PH test may vary by temp and that I should be testing the PH at the temp that my spa will be at normally. That is true correct?
I want to use the dichlor / chlorine method of raising CYA and ongoing sanitation. I have a large jug of Spa Guard Enhanced Shock that I need to use up. I assume that I can use this for the dichlor part of this method. The label says: 58.2% Sodium Dichloro-s-Triazinetrione 41.8% Other Ingredients. The other dichlor products I see being sold are over 99% Sodium Dichloro-s-Triazinetrione. Does this mean that the product I have has more CYA in it, or can I use the section at the bottom of Pool Math to determine how much CYA I'm adding by choosing dichlor and adding about double the amount of Spa Guard Enhanced Shock?
Travis
Travis
