Stable pool all summer.. now PH increasing daily
Feb 16, 2021
22
Courtice, Ontario, Canada
Pentair Intellichlor IC-40
My PH really hasn't moved all summer.. then all of a sudden it seems to really want to move up..
Moved slowly toward 7.9 .. I added acid and 7 days it went from 7.5 back to 7.9.
Tomorrow or Saturday, I'll add acid again..
Yesterday TA was 70 ( It was 80 for most of the summer until I added acid mentioned above )
I keep FC between 4 and 6
CH 110
I think pool logs are in signature if you want to look more
We aren't swimming more then we were ( if anything ..maybe less ) - Water feature is definitely running less than a month ago )
My question.. what would trigger this steady increase in PH compared to before.. when aeration is less than before...?
EDIT: sorry not sure how to share logs... link doesn't seem to work
HermanTX
2,533
Katy TX
Have you had to add fill water? Or do you have an auto-fill? Sometimes fill water with high TA can cause your pH to increase outside of its normal cycle.
Have you tested your fill water?
To share your Pool Math logs - on the app - go to the GEAR settings and scroll down to where it says Sharing - then click the button ON to "Link from TroubleFreePool.com user profile"
iadams
41
Mt. Airy, MD
I use that same stuff nor a non-pool purpose and I write on every bottle in black marker "NOT FOR POOL" as soon as it comes in the house
Feb 16, 2021
22
I did reply to this.. but I've just come back to see of anyone added anything.. and noticed...I didn't successfully reply...
No fill water was added.
I don't have an auto filler.
My logs are shared.. I guess if you look at my profile, there should be as link.
I had to add another 17.5 oz. of acid yesterday.. just keeps creaping up.
Feb 16, 2021
22
It's not currently running at all, I couldn't run salt as I hadn't received my intellicenter panel (with the needed transformer) I have only been added 10.3 liquid chlorine as needed.
On a good note.. I now have the panel and hope to have it installed before I close the pool for winter :)
