I have a Sta-Rite propane powered pool heater that has been sitting idle for a few years, with no propane supplied to it. For the last few days I have been trying to get it running, and I have corrected quite a few things that it needed. I replaced the control board and the SFS sensor, and corrected some wire contact corrosion.
The heater now comes on with the green pool light illuminated, and when I select heat the blower starts running and the yellow heating light starts flashing. After trying to start, the service heater light comes on and the blower turns off. On the back of the control board none of the fault LEDs are on.
I am getting 24 VAC to the gas valve (after the expected multi second delay), and I hear it click when the heater is trying to start. I have good gas flow coming out of the low pressure regulator that feeds the heater.
So I am either not getting gas all the way to the combustor, or the igniter is not firing, but I am not sure which it is.
One of my questions is, if the igniter is not firing and that is the only problem, would the gas be allowed to flow all the way to the combustor and therefore I should smell propane coming out the stack. During my attempts to start the heater, there is no smell of propane coming out the exhaust.
Also, if the igniter is firing, does it make enough noise that it can be heard?
I would appreciate any suggestions that can be offered.
Thanks, Pete V
Thanks, Pete V
