square corner coping for a liner pool
Samantha1
4
bridgewater nj
I have a new 30 x 15 steel wall liner inground with the 6 inch radius corners. We are getting stamped concrete coping and deck installed in a couple weeks. Is there a way to get the corners squared off or do i have to follow the curved corner radius of the liner track? A lot of photos i see look to have square corners on liner pools. My mason is saying to follow the radius or you will see a portion of the liner track exposed if he squares it off. Thanks for the help. Mark
duckcmmndr
402
Arkansas
Hayward Aqua Rite (T-15)
Your mason is correct...if you square the corner one of two things will happen.
1. You will see the coping/top of the wall in the corners.
2. You will have to make your coping hang over the edge of the coping about 3" to get a square corner and cover the coping/wall in the corners.
Neither is desirable, I would have the coping match the corner radius like intended.
