Spalink RS Replacement/repair
zz28zz
2
0
Austin, Tx
#1
Our Spalink RS spa-side controller is dead, again. I replaced it 2 years ago when it died. Now it's dead again. The replacement cost is outrageous. Are there any options? I tried searching for a repair facility but had no luck. Anyone repair one themselves? Thx!
Jimrahbe
10,162
1
Bedford, TX
#3
zz,
Welcome to TFP... a great place to find the answers to all your "Zombie" equipment questions.. :shark:
There is nothing inside the unit but four momentary switches and an Led. The switches go bad from being too close the water. I have not tired, but seems it would be pretty simple to repair it. Runs off of five volts from the automation system so there is no safety issue. Below is a schematic from a Pentair unit.. Color codes are probably different on yours, but the basic operation is the same...
zz28zz
2
0
Austin, Tx
#4
It fits in a cut-out in the brick that surrounds the spa, so I'm pretty much stuck with this size. It went dead then started messing up the inside control panel. I disconnected the spa side controller and the inside unit is fine now. If it's anything like the inside controller, there's not much to it. Mine has 9 buttons and a LED temp display.
