- Jan 10, 2021
- 7
- Jandy Truclear / Ei
I have been trying to solve this problem for a month. I have an inground pool, with a spa that is 1ft higher than the pool. During operation water overflows from the spa into the main pool. There are also a set of three beach jets adjusted manual with a value, and three deck jets. Flow to each is on its own value and there is an automatic value that turns the water on and off to the three deck jet lines.
Each night for the pass month or more, the level in the spa drops at night to the level of the main pool. During this process, the main pool's height goes up about 1 inch.
I have read the various threads here and I had the check value replaced, but that did not fix the problem. Attach is a picture of my setup. I would appreciate it if anyone has an suggestions to test or fix the problem.
