Spa return size
Alwayshad1
Active member
Oct 11, 2020
38
North central Florida
Just had a heater installed for our pool/spa. The spa runs off a separate pump, I think it is 3/4 hp. The guy who installed the heater put in 1” diameter returns and there is hardly any pressure so to speak, not enough that makes it feel like a massage. If I put in say 1/2” or 3/4” returns I know the pressure will increase but will there be any negatives as far as possible damage to the heater? There are a total of four returns in the spa.
ajw22
29,075
Northern NJ
Pentair Intellichlor IC-60
What size eyeballs did you have in your spa returns before the heater was installed?
A 3/4 HP pump is small to get good pressure from spa returns.
Alwayshad1
Active member
Oct 11, 2020
38
I honestly don’t know but I remember when the spa pump was running, two of the four had quite a bit of pressure coming out as the water was visibly swirling and foaming from those. Not much out of the other two.
ajw22
29,075
Northern NJ
Give smaller eyeballs a try and see how they work. It will not damage your Heat Pump.
Smaller eyeballs will raise your filter pressure due to the restriction and may reduce your flow. If your HP complains of LOW FLOW then you will need a larger pump to get the flow necessary for the HP and small eyeballs.
Alwayshad1
Active member
Oct 11, 2020
38
Ok will do thx!
