Spa/pool combo freeze protection - a vote
dphanes
140
NC
What do people think is best for a spa/pool combo with one set of equipment during freeze protection:
1 - cycle between spa mode and pool mode every thirty minutes - con is wear and tear on actuators
2- run continually in spillway mode - con is spa stone wall will potentially go through freeze thaw cycle
really looking for people’s thoughts and what they do
ajw22
38,881
Northern NJ
Pentair Intellichlor IC-60
1
2 is not running water though the pool returns and can allow water in pool return pipes to freeze.
3 reset your return valve for freezing conditions and run water through both spa and pool returns.
dphanes
140
NC
1
Goid point, but I believe u Can change the cam on the actuator to run a little water through pool returns but 90 percent throygh the spillway to address that valid concern.
ajw22
38,881
Northern NJ
You also have …
4 Winterize the pool
My order of preference is … 4, 3, 1
I close my pool for the winter, often go away and ignore it, and never had any damage to deal with in the Spring. I take the lazy way.
dphanes
140
NC
You also have …
If we were up north we would definitely close, but being in NC we get some nice days in winter where we can heat the pool and we use the spa quite often in the winter.
