I am having an issue with my spa. The pool is running just fine, but when I turn on my spa (via the Pentair app) it is not working properly. The water level in the spa will go down, I get some water coming out of the jets but it is very weak, and I am getting a clicking sound every other second which is coming from the valve actuator. I have not touched this actuator since the pool install, and although a year or so ago the handle on it broke off (care of the brutal sun here) it is still worked fine up until now.
I thought it might be the filters or a clog in there since we had a bad wind storm recently, so I cleaned them and did not see any blockage anywhere so I don't know if this actuator just needs to be fixed or replaced or if it may be something else. Anyone else ever had this issue?
Thanks
Note that the super jets on the spa work just fine.
Thanks
