I'm having an issue where when I put the spa jet pump on, it causes water to back-flow out the air vents near the equipment pad/spa pump. Previously the spa water/air jets have worked fine. I can't quite remember the exact date they stopped working but probably April 2020, shortly after spring opening of my pool. However I use the spa year round.
Here is what I've currently done with no result:
1. Remove and clean the spa jet nozzles. I've taken each out to ensure it is clean, full open and then put back in place. Note, when I do have all the nozzels removed, with the jet pump on, the jets pump water but not air.
2. Blow pressured air in air vent. I've used the reverse air on by shop vac to blow air in the air intake port towards the spa. This did not produce air bubbles out the jet nozzels.
I'm guessing there is some sort of air or water lock in the system. Some how the venturi action that is supposed to work is not.
Has anyone experienced this before and have ideas on how to fix?
