Spa Blower Replacement Instructions
ajw22
26,323
Northern NJ
Pentair Intellichlor IC-60
Rubber mallet.
Unless you see any screws it should just be set on the pipe and not glued.
Or you can cut the PVC pipe at the bottom of the old blower. Losing an inch of pipe will not make a difference.
sagosto
239
Mahwah, NJ
The one-way valve is at the bottom right between two elbows. I didn't want to crack/damage anything so I wanted to be sure. I need to replace the valve too so I guess it doesn't matter. What holds the elbows/etc. in place? Or do you always need to cut?
ajw22
26,323
Northern NJ
Post pics of what you are looking at.
sagosto
239
Mahwah, NJ
Picture of the disconnected blower and the valve near the ground.
ajw22
26,323
Northern NJ
If you need to replace the check valve then just cut it out down there and rebuild up.
ajw22
26,323
Northern NJ
Everything gets glued until you place the blower on top. The blower does not get glued to the pipe.
What check valve are you using?
sagosto
239
Mahwah, NJ
Thanks. I was going to use the new one that came with the blower: Puri Tech (2HP/240V - Model: PRT2002403)
ajw22
26,323
Northern NJ
I know nothing about that blower.
