Spa blower installation
Jimrahbe
15,028
Bedford, TX
Mike,
I would wire it to the relay on the bottom right... In "theory" this should be Aux 7.. I suggest that you make sure the little coil wires from that relay are plugged into the Aux 7 port on the main board.
You would wire the blower into the two Load terminals on the relay. You will need to run 240 volt power from the load center to the two Line terminals on the relay.
Unless it is going to be used for something else, you could use the 20 amp 240 volt circuit breaker that is not currently being used.
