I have an attached spa to my pool that has an air line that when the system is in Spa mode draws air from the pipe to mix in and produce bubbles through the jets. The pipe is just a vertical pipe at the valving that has a few holes drilled into it and is tied into the spa return line. I don't have a booster pump for that function and the line always produces bubbles because the line just has holes with no way to close them.
I'd like to if possible put a valve on the air line so that I can control whether bubbles are produced or not. It is a 2" PVC pipe that I could cut and put some sort of open/close valve onto to control the air flow, but I can't seem to find anything online that fits the application.
Any ideas?
Any ideas?
