Some suggestions getting balanced please?
Rona0423
Active member
Oct 11, 2020
29
Olive Branch, MS
Posted a bit back, got my TF-100 in and tested. Any suggestions on which way to go?
I honestly am kinda guessing on the PH. I am not color blind but it gets hard for me to read. I attached a picture.
FC - 13.5
CC - 0
PH - 7.6
TA - 60
CYA - 50
CH - 0 (I am assuming this is correct. It did not turn red)
Chlorine is obviously super high? When I shocked it a while back, I put to much. I thought the scoop was a 1lb scoop but hindsight it was a 24oz scoop. So, I put 3.75lb in a 28,000 gallon pool and it should have been 2 1/2 pounds?
IC40 SWG is running at 40% 24/7. Water is still about 63 degrees.
mknauss
47,872
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
Your pH test is effected when FC is above 10ppm. Wait until that lowers to test pH.
What solid chlorine product did you use?
test your fill water CH. Do you have naturally soft water?
Rona0423
Active member
Oct 11, 2020
29
Olive Branch, MS
We have soft water, yes.
Super Shockwave 25lb — Aqua Fun Pools
Any suggestions for the FC to come down other than time? Lower the SWG perhaps for now?
Is that level safe for the kids to swim?
mknauss
47,872
Laughlin, NV
Fiberglass
It is safe to swim in.
Is that product calcium hypochlorite? The website would not let me zoom in.
Turn off the SWCG for a day and the FC will fall.
Teald024
So an easy way to check pH. It go goes yellow —> orange —> pink —> purple.
you want to be in the pink range. It’s about color, not intensity. Don’t look for an exact color match, just look at what the color is.
Reactions: DanF
Rona0423
Active member
Oct 11, 2020
29
Olive Branch, MS
Had a get together and was surprised these kids got in, but they did. 65 degrees. Anywho, had the SWG off all day, tested after the party ended and it has dropped to 9.5 - I will leave it off through tomorrow (going to be 80 and sunny) and my guess is it will come down more.
mknauss
47,872
Laughlin, NV
Fiberglass
Be careful. Turn the SWCG back on tomorrow sometime as you do not want to drop too low on the FC.
put the CH @ 75. Is that to be concerned about, in vinyl?
No.
Rona0423
Active member
Oct 11, 2020
29
Olive Branch, MS
Okay - Think I should go ahead and throw it back to 40% which puts it 2-3ppm since I’m running the single speed 24/7?
Also, the TA and CYA are a bit low aren’t they? Should I worry about pulling them up now? I have the pool math app and subscribed to it to keep all my logs.
mknauss
47,872
Laughlin, NV
Fiberglass
Sounds good.
The TA is fine. The CYA can be gradually brought up to 70-80 ppm over the next few weeks.
