having an issue with some pool posts leaning sideways, (not in or out from the wall). I have a Vogue resin pool and i can say that i am about 1" or less out of level even though my transit when levelling said i was good on each of the 14 pads for the plates. In any case, i'm not sure how detrimental this is to the rigidity of the pool itself with the posts leaning a bit sideways. There is about a total of 5 or so that lean a bit over. I also have a slight issue with the way the top rails interlock with each other. Some of them locked in really well where about 5 others are a bit off. We've been swimming daily in the pool without issue. Seems to be holding really well and as mentioned is quite level. I guess when i drain down to about 2 ft or so for winterization, i can take off the top rails and readjust by tapping the posts so that they look level again to the naked eye, but i swear when i put these posts into the foot plates that they were all straight. then again, when i was adjusting the top rails i may have pulled the rail over to get it to finally finish fit the circle. I was about 5-6" out IIRC to get the rails to fit at the end.
Seems when the water pressure built up against the wall they moved? then again, maybe they were always off?
thoughts on this?
thoughts on this?
