(I composed this post earlier but I can't find it, so sorry if this is a double post)
I mentioned being very grateful for the help I've received here and look forward to the day when I can help others.
Anyway...I have an 8 section (about 26' total) Solocol solar heater for my small 5850 gallon pool. I just replaced my pump with a new TriStar VS 900. There is an automatic valve that diverts water thru the system based on the available sunshine, and the pump changes speed when this occurs. I'm new to all this and have been unsure of the pump speed required to get the most out of my solar heater. I don't know how to figure how many GPM the pump pushes at any given speed or if that is even a valuable statistic. How can the optimum speed be determined to get the maximum benefit? Is pushing a lot of water quickly thru the tubes better, or is a slower "trickle" better for heating up the water? Thanks (again) in advance.
