Solar pump not working properly
Sharonjh
0
60
Australia
Hi,
I have solar heating which is run on the filtration plumbing. ie have to have filter pump running while solar pump is running. When I turn the solar pump on and I hear it running but it will only start to push water to the solar absorbers if I crack open the discharge union on the pump for a second or two and allow some water to come out. Any ideas what might be happening?
Sharon,
Are the absorbers elevated? Do you have a vacuum breaker installed? Was it working previously? A photo or two would be helpful.
Chris
The absorbers are on the roof. I think this is the vacuum relief valve. When I unscrewed it I heard air being released so it must be faulty. Can’t find a replacement one that looks the same.611FE65D-D18F-41C8-8BDD-FD53C2436439.jpeg
