- May 19, 2021
- 207
- Fiberglass
- Pentair Intellichlor IC-20
Hey guys - I did do some searches, but found rather old threads, also didn't see anyone with experience in my climate region. (Charlotte, NC)
When I did the pool install last year, I was not sure about what the temperature of my pool was going to average, and whether I might want a heater / chiller, or just a heater for instance. I have had some experience here where some pools that were in 100% sun get warm enough in the summer that I did not find them refreshing or enjoyable.
So I held off on deciding between gas or electric heater/chiller combo.
Into my second season, and I am really thinking that solar might be a good option. I have enough shade from trees and my house, that I have only hit 90+ a few times (plenty hot for me, but doable). Solar does not seem popular at ALL around Charlotte though, and I am curious to see if I have any 'neighbors' that have tried this, and with what level of success. I am specifically asking about manufactured panels, not the ones you make yourself (I have done that for a small pool with success, but the low flow rate required would not make a sufficient difference).
I did some research and other than location specific feedback, it seems that it might be a good way to go for my situation. I have a roof over an addition with easy access to my current equipment, as well as low height, and probably a good angle. My goal would really be to extend the season by about a month on either side of summer. Personally, I like about 82deg water, but I will start swimming when the water is around 74. I use a solar blanket at night to retain the heat in the spring and fall, so that would also be used in conjunction with the solar heater.
I think my EasyTouch can control the system, but I'd probably have to confirm that.
Thoughts? Experience? Additional things to consider?
