Solar cover worth it swimming nearly every day
CJadamec
2,323
Quaker Hill, CT
It depends on what you consider "worth it". The solar cover will make the pool warmer and reduce chlorine lose to the sun burning it off. They also help to keep dust and leaves out of your pool they won't keep everything out but it does help to stop some of the stuff.
If you find the solar cover difficult to handle or a pain to remove and put back on then you likely won't use it very often. If you aren't using it because its not easy to use then you likely won't consider it "worth it".
I always try to recommend you plan ahead for an easy way to get the cover on and off the pool. This generally means some sort of cover reel.
DorsalSpine
224
Columbus, Ohio
You definitely need a cover reel. It's easier to get the cover on with two people. I can reel it off by myself but my wife can't. Having it on at night will help keep the pool warm.
splashpad
1,979
SE Kansas!
It cuts down on evap too :) We only have a 15' pool, but we do think it's worth it. We swim in the evenings and weekends, so not having to spend extra time "cleaning" (as noted by @CJadamec ) is "worth it" to us.
If your pool has issues staying at a swimmable temp, it could be worth it, but if it doesn't, it might make it warmer. Our pool is under lots, and lots of trees.
BuckeyeMac
136
Carroll, OH
This is my first pool/first year with it, and I have a solar cover in the barn. I will be swimming almost every day/night with wife & kids, and to help with evaporation I will use it for that purpose. Might be a pain putting it on/taking it off every day but the pros outweigh the cons for me at least!
Reactions: splashpad
LFrankow
530
Medicine Hat, Alberta
Our cover goes on after swimming even if using the pool daily, we got caught by a cold front one year lost 2 days of swimming because we didn't put the cover on one night...…...
I made a "solar reel" out of 4" white pvc drain piping, 3 pieces of pipe and two couplings, it rolls along the top rail fairly easily. I added a handle to one end this year to make it easier to use.
To get the cover to stick to the pipe I simply wet the "roller" down with pool water, friction does the rest.
scdaren
334
Clovis, CA
We use it to prevent temperature loss overnight, especially at the start and end of season when running our heat pump. For that, yeah, well worth it. It saves like 3 degrees of temperature loss overnight, which translates directly to money saved on heating costs.
If you aren't heating, it will still work to keep your water warmer by eliminating the overnight temp loss, if that's something you want.
cfherrman
2,207
Hays, Kansas
Thanks guys I'll probably pick one up! Pool is hovering around 62 degrees we usually don't swim until later may I'm hoping a cover will help.
PoolGate
3,007
Damascus, MD
I decided after the 2nd time taking my solar cover off that it wasn't worth it. Anything that collected on the cover dumped in the water when I removed it and I had no real place to store it once off. What a PITA is was! I'll just eat the heating costs, which are admittedly substantial probably cost me an extra $100/month to heat without it. I have no place to store a cover really either without it being really obvious. We also like to sit out by the pool and drink margaritas at night. I don't want to look at that cover. For us really it was purely a financial decision. For my $85k the bottom line is I am not too terribly concerned with an extra $500/season in heat loss enjoying my oasis.
cfherrman
2,207
Hays, Kansas
Yeah definitely, I'm going with a diy reel or diy hooks on the side of the pool, otherwise it's on the ground collecting grass ending up in the pool
Thread starter Other Threads of Interest Forum Replies Date
C Everything Else 1
M Everything Else 7
M Everything Else 1
