I got a solar cover for my above ground pool this season. Since getting it I have noticed that when I leave it on I see a lot of what I assume to be algae appear across the bottom and on the sides. It doesn't seem to appear in the vertical sides of the pool only on the the ripples in the liner where there is a horizontal surface. I'm not 100% certain it's not pollen but I'm treating it like it's algae. Last time it happened I did a slam and left the solar cover off and didn't have any issues for 2 or three days until I put the cover on. When I put the cover on it started to happen again.
I didn't modify the cover at all to trim the circumference or cut it in half. What are the recommendations for this?
My chlorine has been around 4 the whole time and my pH is a little low, around 7.2, but it seems like that's ok even if not ideal. As I understand a little low is better than a little high as far as chlorine effectiveness goes.
I'm thinking that if it is algae that I need to trim the edge of the cover to try to improve circulation. I suspect that the problem is either circulate or that it is actually pollen that is on the in the cover getting into the pool water.
Sorry, I know this has been discussed ad nauseum but I wasn't seeing recommendations for how to modify the cover for the pool.
