This post was split from Solar SWG?
hmmmm I decided to see if anyone had success with Solar Chlor XT after I bought one. It was reduced to $70 on eBay so I took a gamble. This thread doesn't sound like I will have positive results but I will report back. I live in north Georgia and have covered my pool for the winter (left it open last year) and only use the integrated spa a few times over the winter so chlorine demand is low. As the spa is integrated and I currently run the pump in both pool and spa modes to keep the entire water system in balance. In addition when freeze protection runs it circulates water from spa into the pool so I have established the recommended salt lever in the entire 25,000 gallons. The Solar Chlor is floating in the Spa much like the robot system Matt described. It went in the water a few days ago and I will monitor chlorine levels and see how it goes. If it doesn't work I will be able to plumb in a generator fairly easily. Even if it only works for my low demand winter conditions and I have to install an inline system for warm weather I will be satisfied.
