- Jun 1, 2018
- 7,265
- Vinyl
- Intex Krystal Clear
Were you using the pool pole as a lighting rod? Not advisable lol !
This rain and temp drop made it feel like winter instantly.
I would still put a closed cell foam pad under the cover for added protection.It's got reinforced patches on the stair corners as promised
I'll fill them with polymeric sand to match. The anchors go through the slab under the pavers, they aren't going anywhere.The holes look like they are too big.
Yeah. No two of the springs are compressed the same.Some straps look a little bit loose.
No explanation there but LAZY.don't like the one strap that's at and angle other than 90 degrees.
I would probably use colored tile grout from Home Depot or Lowe's.I'll fill them with polymeric sand to match.
That sounds great. If I waited until spring I could center the anchors while the grout hardened.I would probably use colored tile grout from Home Depot or Lowe's.
Thanks.Granted, I know nothing about covers or closing a pool, but it all looks pretty good to me.
I agree. I'll come out too; I have a long history of epoxy use.Epoxy injection with a sand finish … do it right. I’ll be out in the spring to help, just keep the beers cold.
