So... there is no bleach in this town. Should I use pucks for a while...?
Strawberryshortcake
241
Hot Springs, Ar
I'm not in dire need yet, with the temperature still cold my pool is only needing bleach every few weeks.
However, it's warming up, and there simply isn't any bleach due to the virus. Every store is wiped out, and to be honest, I am not going to keep going back in the next few weeks as this evolves to check for more stock because of course I don't want to catch it either! As someone with health problems, I am pretty concerned, but I really don't want my pool to go swamp mode after everything we did :(
My pool currently has 0 CYA. Is anyone else looking at using pucks in the meantime? Or is it just my little town that has had a run on bleach? How long could I get away with using them?
Jimrahbe
16,926
Bedford, TX
SSC,
We are not against pucks, just the unlimited use of pucks without testing.. As long as you can test and ensure that your CYA never goes too high, then puck use is just fine.
Reactions: JodieM
kimkats
44,783
Tallahassee, FL
Look in the pool supply are of Walmart (or have someone else look for you). They have the "pool shock" chlorine. Most people don't know it is "hotter" bleach so there might be some of that left.
kim:kim:
Reactions: thefloatqueen
Divin Dave
5,653
Longview, Texas
I was in Wal Mart last week. Not a bottle of bleach anywhere, but the shelf was chock full of Pool Essentials liquid chlorine. Not sure if the world has caught on by now or not. I havent been back since then.
3.64 a gallon.
Other resources are Home Depot and Lowes, at least where I live, they both carry it in the pool section behind the trees and flowers.
Some pool supply stores carry it and others dont, so thats a possible source of you too.
derek533
Active member
Mar 23, 2017
31
Edmond, OK
Home Depot sells liquid chlorine for pools but beware that around here, it's always stored outside in lawn/garden where there is so much temperature fluctuation that any benefit of getting the higher percentage bleach is negated. It's usually also much older and will have lost 50% of its potency too.
I was in Walmart two days ago and the pool section was full of the Pool Essential's stuff with a julian date of the 347th day of 2019. I bought 18 gallons myself and there was still at least 200 left if not more. Luckily, hoarders of supplies aren't the smartest bunch and haven't figured out what it really is since it says Pool Essentials instead of Clorox.
scdaren
351
Clovis, CA
Sounds like a good excuse to install a SWG!!
Where I am, stores are out of bleach, but most of the time they have full stocks of "pool chlorine", at least until non-pool people figure out it's the same thing as bleach. But probably a lot of regions don't sell pool chlorine in grocery stores like they do here...
I've found the chlorine at Lowe's to work just fine, and they store it outdoors and it gets very hot where I live.
scdaren
351
Clovis, CA
Also, you can try commercial chlorine suppliers. At my work we buy 330 gal. totes of 12% from a company called Brenntag Pacific. They are located all over the country. I think they sell smaller containers, but I'm not sure how small. Drums maybe?
Strawberryshortcake
241
Hot Springs, Ar
SWG is on my list of upgrades... eventually! 😝 I can’t afford it right now but man do I hate lugging bleach around.
I don’t have a home depot and my local lowe’s has pool chlorine that is always a year or more out of date 🙃and they store it outside. Pool chlorine was gone at my walmarts. No home depot nearby. (yay small town).
Still no bleach.
Probably going to get some pucks in the meantime...
mknauss
26,617
Laughlin, NV
I would not recommend buying that many. Home Depot and Lowe’s carry smaller amounts.
You need a floating dispenser. Also available at Home Depot or Walmart.
C3Cl3N3O3
193
Fort Mill, SC
They have the 10% at Lowes but I drove by and the parking lot was mobbed so I kept driving. I'd rather have a green pool than be green in the gills myself.
Why is everybody at Lowes today? Lowes is still open LET'S GO THERE.
