So confused.
Flynnranch
49
Lipan tx
Hello there! I am attempting to get our pool clear for the first time this season. All summer we have struggled with algae and cloudy water. I have spent hundreds at the pool store with them telling me what to do and finally decided to wing it myself. I'm sure I have done everything wrong and thrown more at this pool than is feasibly worth it, but I'm not giving up. Is there someone who can guide me in the right direction? I have replaced the sand in the filter as of yesterday, it was three years old but it was really gross. I have pictures of my test strips and the Chlorox Pool app analyzer if that helps at all.
Thanks in advance!
TH 500
TC now at 5 after shocking this morning, but has been at zero
FC same as TC
PH was at 7.8, now lowered to 6.8
TA was 180, ow at 240
Stabilize has not shifted from 0, despite twice putting the HTH Pods in. (2 each time)
I posted pics, but they aren't in any order. :cool:
Oly
1,151
Fresno, CA
Your testing method is making your life difficult and balancing your pool water impossible.
Upgrade you testing procedure to a titration method or "drop test" and everything will fall into place for you.
TFP recommends the TF-100 or the Taylor K-2006C.
Reactions: Flynnranch
IceShadow
1,070
Milwaukee, WI
Welcome to the forum!
Good news and bad news. Good news is that you've come somewhere where people can absolutely help you to take control of your pool, the chemicals, and guide you through cleanup. See any of the other threads here for tons of success stories from people who have struggled with cloudy pools.
Bad news is that we really can't give advice based on test strips. They're notoriously inaccurate, and if we tried we could be making things worse. Same with pool store tests - once again, we don't trust their accuracy and don't want to give you advice based on faulty numbers.
Get one of the test kits mentioned above first. Once you have those you can post test results that we can trust to give specific guidance for your pool. For now, I recommend putting in 5ppm worth of liquid chlorine (bleach, "liquid shock", etc. - no additives, no Clorox brand, no scents or "splashless" or anything, just plain old bleach) daily until the test kit arrives.
Oly
1,151
Fresno, CA
Check out these videos for no nonsense pool maintenance information.
Flynnranch
49
Lipan tx
IceShadow
1,070
Milwaukee, WI
Practically speaking they have the same chemicals - all manufactured by Taylor. The TF-100 comes with less of a few that aren't used as much and extra of the FC/CC testing materials, especially if you get the XL option. The Taylor kit comes with what I think is a nicer case.
Do NOT get the Taylor K-2006. Only the K-2006c. The "c" is important - without that you won't have enough reagents for the FC/CC testing. :)
Teald024
Hello and Welcome to TFP!!
Be very cautious about using price as the decision maker with a test kit. What looks like a value now, may lead to less value later. I highly recommend the TF-100 kit with XL option from TFTestkits.net. The K-2006C is a decent kit, but it does come with smaller bottles of drops than the TF-100. This leads to fewer tests for the money. Most people end up buying refills before the pool is totally clear. You do get a pretty blue box with the K-2006C though. Just my 2 cents.
Getting the XL-option now will save you from needing to get refills later and therefore save on the shipping costs.
You are battling the algae and the sun. A perfectly clean pool will loose 2-4ppm of chlorine per day. If your CYA is really zero, then the sun will burn off all the chlorine in a few hours. Don't add any CYA for now until after you get your test kit.
Just add 5ppm of FC per day (one gallon of the 6% bleach).
Msch99
380
Verona, MO
Welcome to TFP! :) You will not regret taking charge of your pool!
While waiting you may want to add plain bleach to raise your FC to ~5ppm.
Check out pool math to calculate how much to add. Use only plain, unscented bleach. Do not use chlorox it usually has other additives you don't want in the pool.
(while typing I see Teald already advised this)
Do not add anything else until you have test results from one of the test kits. Post your results and let one of the experts help get you on track.
Also check out Pool School while you are waiting. A ton of information that may seem overwhelming at first. It helps to get used to and understand some of the terminology. The experts are always here to give a hand for specific questions, so you don't have to memorize it.
Addyour pool information to your signature, similar to the ones above. Settings/signature. It helps the experts to know what equipment, type of pool and location so they can give you knowledgeable advice.
Good Luck!
Jason245
72
Fort Lauderdale FL
As an Owner of a K2006 (I bought it for the Blue box... ), I can see the appeal of having the K2006C or the TF-100 for the increased testing liquid sizes.
That being said, In my 2 months of ownership I have realized that there are really only 2 things that look like they will "run out fast" from my 0.75 OZ containers. I don't think the 2006 gives more powder in the C or regular.
The FAS DPD Regeant
CYA testing Regeant.
I bought some small Funnels and for less than $50 I was able to get 16 OZ bottles of each of the regeants (2 ozs replacements of each sell for ~$10 bucks each so refilling bottles is a huge savings).
The Powder can be got for ~$10 for the same size (or if you want a bigger size $30), but that seems to last a while if you don't over use it and comes with a new spoon (which may be a plus).
Personally, I don't know if the 2OZ bottles for the Taylor K2006C are worth the premium (which I instead put towards the extra larger sized 16 OZ regeant bottles for CYA and DPD) so I am satisified with that decision, but who knows, maybe in 4-5 months I will realize what a fool I have been (based on my usage pattern, I believe I everything else should last about that long except for the powder and maybe the PH regeant which I may end up getting a 2OZ replacement).
Uncle Salty
292
South Carolina
Do yourself a favor and order the Magnetic Speed Stirrer and a couple extra magnetic stirrer bars when ordering your kit. This makes testing easier and more accurate in my opinion.
Salty
CraigW
21
Riva, MD
Just wanted to second Uncle Salty's recommendation for the speed stirrer. Best money I spent (other than the test kit). It makes it so easy when you're adding reagents drop by drop since they're immediately mixed.
Reactions: Uncle Salty
PointeTaken
57
Hoover, AL
The 2006c gives two little bottles/scoops of the powder. I believe the 2006 only gives one.
I'm in agreement with Jason; I don't know that the overall value is any different between one or the other after pricing out the cost of the kits and the price of the large "E" sized refills of the most-used reagents. It appears to be a wash and probably ends up being a matter of personal preference (and some convenience) tailored to each individual's use.
If I had to do it over again, I'd probably buy the 2006c, but I don't feel in retrospect like I need to replace my 2006 with the C model.
Flynnranch
49
Lipan tx
Hello there! I posted the other day about going around in circles trying to get my pool clean, it was recommended that I purchase a good quality water test method. Well it has arrived in the mail but before I start, I have a few questions.
My filter has been running constantly, do I need to brush the pool and stir up all of the green stuff on the bottom before I test, or do I just test the water as it has been circulating?
Flynnranch
49
Lipan tx
Thank you all! I just kind of cross posted as I have my kit now! Do I just test without brushing? The filter has been running 24/7 so the water has been circulating, was not able to add bleach yesterday.
