Smoke coming from Pump
redmenace20v
7
Jacksonville, FL
Just completed my first Mustard Algae SLAM. Pool looks amazing now.
Pump has been running 24/7 for 5 days. Has been raining for 24 hours with 90%+ humidity.
This morning noticed pump was off and it tripped circuit breaker. Turned it on and smoke came out from that piece screwed onto the top.
Do I need a new pump? If so, what do you recommend? I have a 15,000 in ground pool and a cartridge filter. I don’t have a good place to backwash/vacuum to waste without hooking up a 100’ drain hose and running it to the street.
Texas Splash
Welcome to TFP! :wave: That's a capacitor. Fairly easy item to replace if you have some basic DIY skills. You do want to make sure to replace it with the same part number. @JamesW has a lot of those memorized, but if he doesn't post soon you can call InyoPools and I'm sure they can confirm the right replacement.
redmenace20v
7
Jacksonville, FL
Thanks! Here’s some photos of what it looks like under there
redmenace20v
7
Jacksonville, FL
Hahaha. Glad it was just the capacitor and not the motor.
I ended up ordering this one as it had the fastest ship time. Don't want my Mus Algae SLAM to go to waste. I hope this one will fit:
