Hi there
I have an Intex XTR 18 x 52 inch pool that I finally got put up after several weekends of leveling and prep. It's not perfect but it is under an inch out of level (approx 3/4).
The only odd thing that I can't seem to find examples of people with the same issue is that all of the legs are leaning in very slightly. Maybe I'm just being a hypochondriac (nothing new there) but it is the same amount all the way around (between 1/8-1/4 inch) and if I pull back at the top of the frame (simulating pressure pushing outward from the inside like if someone was pushing against it while inside the pool) they are perfectly straight.
All things considered and since it's consistent all the way around my thoughts are it's probably going to be ok, but would definitely appreciate some advice on this.
Thanks!
Thanks!
