Heya,
I have this perception that my small 10ft 1100Gal pool has a white-ish haze to. It doesn't feel "crystal clear" to my eye, but I don't really know how clear to expect the water to be.
I opened (setup and fill, no over-winter) it a couple weeks ago, brought the FC to about 10 and let it naturally settle. All other readings seem fine and I've been adjusting daily with dichlor, muriatic acid, baking soda, borax and cya as needed. It's mostly dichlor and muriatic since my Intex pump seems to aerate a bit and the pH rises. I only use test strips and a small separate kit mostly for more accurate pH, so I could have a chemistry problem, but it all looks good.
Looking at the picture, is it just my imagination or should the base of the ladder be perfectly clear? The water is only 3ft deep.
If it is a bit hazy, what can I do about it? I upgraded the pump/filter to the Intex 2500GPH and it can really move the water through the filter in short order.
Thanks!
Thanks!
