Slide vs ball
ferretbone
In The Industry
May 24, 2016
164
tx
Check valves with flaps are better, Jandy makes some good ones, these are a little cheaper else where but here is what jandy and fibero look like Amazon.com: FibroPool 1 1/2" POSI- Close Non- Lube Check Valve : Industrial & Scientific
Dont use slide valves use these Amazon.com : deverter valve
They dont get as stiff. When they do get hard to turn you can open them and lube em.
Jandy, hayward, pentair all make good valves. I like hayward best. Look to pay about 40 each, You can find them cheaper at pool wholesellers that are not on amazon. I just bought a case of hayward two ways for 27 each. So shop around.
You will hate the ball valves.
Reactions: UKjames
UKjames
221
United Kingdom
Thanks! I notice that has a spring is that better than without- I wondered about extra effort for the pump?
Im struggling to find those in the UK. Although- I know last time I said this for something, someone here found them!
UKjames
221
United Kingdom
Do you know what options are available on the pentair you link to?
Can you split and adjust the weighting of the flow between two outlets as opposed to 1 outlet or the other?
UKjames
221
United Kingdom
Ordered some of those pentair ones hopefully the import duty won’t smart too much! Thanks for the link
reading around this site seems that I don’t need a check valve between swcg and heater you only need a check valve for a puck feeder..
