My pool is currently a green cloudy mess that appears to be getting worse. It's 16x32 and I can't see to the bottom even on the shallow end. After years of struggling to fight off algae by making tons of trips to the pool store with no help, I found this site and I hope to take control of the problem myself this year.
I'd like to start to SLAM the pool, and I now understand I need to measure CYA and FC and bring FC to a certain level according to the chart for several days and I'll have a clean pool.
The pressure on my filter tends to rise from 22 to 30 every few hours. I backwash, rinse, repeat, and am able to get it down to 22 temporarily. I have a DE filter and I've been using "Pro Guard" cellulose fiber instead of DE (they claim it works better...not sure if this is true). So I assume I'm supposed to add more cellulose fiber/DE every few hours after I backwash the filter? This seems like a very expensive thing to do.
My questions are:
1. When/how often should I clean the DE filter grids completely (i.e., drain the filter and hose off everything)? Should I do it before SLAM? After SLAM? Before and after SLAM? At the end of the year?
2. When my filter pressure raises from 22 to 30 every few hours, does that require me to backwash it every time? If so, am I supposed to be adding cellulose fiber/DE every few hours?
I intend to order a Taylor K-2006 test kit to start he SLAM process, but unfortunately I've called 5 pool stores and none of them have it in stock. I'm going to order it on Amazon unless I can find it tonight. If anyone knows of any chain/brick and mortar shops that carry the test kit that would be helpful as well. Thank you all!!!
My questions are:
