Hi all,
I haven't seen much other pool equipment, but I'd guess mine is typical in that you can direct water coming to the filter/pump through either the main drains or skimmer (to various degrees), and water returning to the pool can run out the wall jets or to the positive pressure vacuum (also to various degrees). When SLAMing, does it make sense to send all the water back to the pool through the vacuum and bring all the water leaving the pool through the drains? Seems like the skimmer and jets won't contribute much to removing the algae that gets swept up.
Matt
Matt
