Thanks to TFP we are almost ready to swim after opening our pool a week ago (has taken 3 weeks in the past.) Completed the overnight test and here are my numbers this morning:
FC 18.5 (we SLAMed at higher level because we had some black algae around pool lights)
CC .5
Ph Didn’t bother testing due to high chlorine. Was 7.2 when we started SLAM. Assuming it’s higher due to rain & addition of water.
TA 110
CH 180
CYA 30
Salt 3000
So, now that balancing can begin, here are my questions:
- In what order should I balance each item?
- Adding CYA will lower Ph some, right?
- When should we add salt? Will that increase calcium hardness?
- What is an acceptable FC level to put on the actual SWG (we still just have the plain pipe on) ?
Thank you so much!
Sus
CC .5
TA 110
CH 180
CYA 30
Salt 3000
Thank you so much!
Sus
