Hello Everyone, my construction is complete and I'm second guessing what my pool builder did. He indicated he forgot to plumb for a drain to support the booster pump so he tapped into 1 of my 2 skimmers. This resulted in my booster pump drawing water direct from my skimmer to the booster pump that is feeding my grotto. I have the following equipment below and also included some pics. My complaint when he just had everything running off the variable speed pump was the water flow was not that great for the grotto. So he installed the booster pump and I don't like the idea that my water feature is using water direct from the pool / skimmer and not going through the filter. I think long term this will be bad. Also I indicated that I wanted to have the water feature on while I was in the Spa to block out noise or others hearing my discussions in the back yard.
Is there something else that could have been to not lose a skimmer? Someone suggested he could have done a 3 way valve or maybe programmed the variable speed pump to support. Is what he did correct or could there have been something else better? Thanks in advance for reading and providing advice.
Pentair Equipment
3 HP Variable Speed Pump - Currently supports a 35K gallon saltwater pool with 5 returns, 2 bubblers in the tanning ledge, and a spa with 5 jets, 1 drain, and 1 return in the bottom when not in use / pool filter is running
1 HP Pump - For my cleaner
1 HP Pump - Added after to support the grotto water feature. Currently plumbed direct to skimmer as a water source going to water feature in grotto
Pentair Equipment
