Hi Folks,
Installing a new AGP with wall foam. Question regarding the gasket for the skimmer and return jet.
Is it best to just sandwich the two gasket surfaces with the wall foam between the liner and metal wall? Or is it best to trim the wall foam back from the cutouts about an inch or so? The latter so as you tighten down the mount screws or collar, it will be a tighter fit between the liner and metal wall, perhaps too much give with the wall foam in between?
-J
-J
