Skimmer and return
Rayraynj
In The Industry
Nov 28, 2021
9
New Jersey
I am constructing a in ground Gunite pool 15x28 arond 15,000 gallons. Question is if I install 2 skimmers how many returns should I have. Some people are telling me 6 and others say only 4?
Heater is 400 BTU
Filter 320
Pump 2 HP
IC40
Thank you!
ajw22
33,361
Northern NJ
Pentair Intellichlor IC-60
Welcome to TFP.
3 to 4 returns is plenty for a typical rectangular pool.
What is the shape you are building?
Reactions: Rayraynj
Jimrahbe
25,127
Bedford, TX
Ray,
I like the idea that each "wall" of the pool needs a Return.. Easy to do for a rectangular pool, but the same basic idea applies to any shape pool..
I don't see what the number of skimmers has to do with the number of Returns.. :scratch: As a minimum, I like two skimmers and 4 returns. Each skimmer is connected back to the equipment pad with its own Jandy valve.
Reactions: Rayraynj
Rayraynj
In The Industry
Nov 28, 2021
9
New Jersey
Ray,
Ok thank you! It is a rectangle shape. This is my first pool I am contructioning.
ajw22
33,361
Northern NJ
Reactions: Rayraynj
Rayraynj
In The Industry
Nov 28, 2021
9
New Jersey
I am constructing an in ground pool in NJ and was quoted 3,000 to rebar on a 15x28 size pool which seems to be reasonable (2x bench and steps) My question is around the plumbing costs. I was quoted $4,300 for two skimmers, 4 return and two main drains with relief valves. Is this a reasonable cost which includes PVC and fittings? This does not include the hook up to the equipment which I thought it did.
ajw22
33,361
Northern NJ
Let’s see what @jimmythegreek says.
wireform
In The Industry
Aug 15, 2017
3,681
Spring Valley, NY
Can we assume the main drain has its own home run to the equipment pad and the same goes for the skimmers each with a home run to the pad. Skimmers and MD need to be minimum 2" pvc all the way to the pad.
