Sizing DE Pool Filter
dcjpensacola
3
Pensacola
Hi!
I have a 22k gallon in-ground salt pool, my pump is 1.5hp. I am replacing my ancient sand filter w/ a new DE filter. I have one picked out but I just want a second opinion...thoughts?
This is the one I am looking at (Hayward Pro Grid DE filter, 48sq ft):
PoolGate
5,592
Damascus, MD
Jandy Aquapure 1400
My second opinion is to dump the mess of DE/Sand and get a cartridge filter instead. DE filters are obsolete and back from the days when they thought the filter was what made the water clear. Cartridge filters require almost no maintenance simply clean the cartridges once a season (takes about an hour). No multiport valves or grids to fail or water to backwash.
dcjpensacola
3
Pensacola
Do you have a product recommendation? Or a size recommendation based on the specs I provided? Do you think 200sq ft would be sufficient?
PoolGate
5,592
Damascus, MD
Jandy Aquapure 1400
What size is your pool? What brand is your equipment? Really any quad cartridge filter would be fine.
HermanTX
1,589
Katy TX
@dcjpensacola Create Your Signature to help us understand what your current setup is so you do not need to repeat it everytime you ask a question.
For 22k gals, I would go with a 300 to 400sq ft cartridge filter. You do not state if you have a VS pump other than 1.5hp but if you do that works great with a cartridge filter but a single speed works also and the larger filter area will reduce pressure drop across it.
Dawagonbus
23
Phoenix, AZ
My 2 cents.... I just got the Pentair Quad 100 DE filter for my 19000 gal in ground. I hope to only clean it twice a year. No back washing for me...just break it down, clean and recharge. I went oversized on purpose.
YippeeSkippy
16,045
Evans, Georgia
I'm curiious as to why you want to get rid of a sand filter that allows you to lower your pool level after those notorious FL rains? You can always add a bit of DE to your sand filter and get the benefits of it.
I find my sand filter so easy to deal with I can't imagine getting rid of it at this point?
Maddie :flower:
