Simbio 30 above ground for salt water pool
cfclay
233
Lexington,Ky
I'm moving again and this time getting a 30' above ground. I've had an Intex with a salt water system for the last 6 years and come to enjoy that.
The simbio is not an aluminum pool someone (not the dealer) pointed out to me. Is that less than ideal? See dealers suggested an all aluminum pool.
Teald024
Simbo looks like an all steel parts except for the resin top caps. The salt level in a salt pool is relatively low and shouldn't cause any adverse issues. Typically pH has a greater effect on equipment and the pool itself. There are a significant number of non-salt pools that suffer from rust issues, unfortunately.
If this is the pool you have chosen, then don't let a SWG or salt stop you. Obviously, the more resin components, the less chance for rust.
Reactions: cfclay
cfclay
233
Lexington,Ky
Thanks for your reply TealD! Another question about this setup. Dealer uses an over the wall type salt water device. I just had never seen that. Is this normal?
