Hi pool people,
Question is about XPS foam. I am putting in a 27' Saltwater Aurora above ground pool. I've dug down to undisturbed ground, and getting the final level done.
I have seen seen builds that incorporate XPS foam sheets. In my case, I can just put down 3" of sand and level it. Or I can put down 2 1/4" of sand and then XPS foam (with triple taped seams). Planning on an Armor Shield on top either way.
Is there a reason for XPS with this setup? It will cost several hundred dollars for XPS for this size vs. $30 for another cubic yard or so of sand for the last 3/4". If I just go with 3" of sand and no XPS, the Armor Shield will still protect against grass/critters/footprints in the sand.
Thanks in advance, you've all been a big help!
