I would check in the main panel box if you have any neutrals and grounds crossed. Check if at the neutral bar if any of the neutrals were stripped long and protrude onto the panel casing grounding it too.
Unfortunately, my panel is from the late 1980's; grounds and commons share the same barI would check in the main panel box if you have any neutrals and grounds crossed. Check if at the neutral bar if any of the neutrals were stripped long and protrude onto the panel casing grounding it too.
Is there a particular MHz range that you would recommend?If you can get an oscilloscope to document the waveform characteristics, that might help us to figure out where the stray voltage is coming from.
I live in Delaware. I opened the pool in May but really didn't start swimming until early-mid June. The only work done was the solar panels being taken off and put back in because we had a new roof installed. I'll certainly do my best to see if anyone has had any work done. My neighbor also has an inground pool, I'll reach out to them to see if they can do some testing as well. Thank you for the links to those other threads, I'll certainly go through them.You said the shock started in June 2021.
Where are you located? Is your pool seasonal or open 12 months out of the year? Where you using your pool in May that you know this began in June?
Any work done in your house or property before this started? Go around and ask your neighbors if they had work done?
Ask around and look for an electrician who retired from the power company and understand the details of the electrical grid and how to find a current leakage to ground. They also know how to work the power utility bureaucracy for assistance.
Finding stray voltage sources take a lot of detective work. Here are two threads to give you ideas of what you are looking for:
Here is a thread that has been going on for 6 years trying to find the source of a tingle - A Slight Shock.
Here the voltage source was a streetlight connected to the house power line Bonding Issue In A Pool.
I had them come out to check everything. They disconnected the entire system and the voltage was still there.So what you just stated is the solar equipment was moved about with the roof work. Maybe that's where your issue is.
What I was just thinking. Doesn’t that tie into the main somehow.So what you just stated is the solar equipment was moved about with the roof work. Maybe that's where your issue is.
Yes, it ties right into the main breaker. I just undid the ground connection coming from the solar equipment and had 400 mV on it. @JamesW That looks like a wonderful piece of equipmentWhat I was just thinking. Doesn’t that tie into the main somehow.
Is the handheld portable type worth looking into?If you can get an oscilloscope, it would be interesting to see the video so that everyone can learn what these signals can look like.
Anything that can give us a look at the actual signal should be helpful.Is the handheld portable type worth looking into?
I just wanted to give kudos to this group for helping. I was having issues wiring a GFI and a timer and asked on an electrician forum and was pretty much called an idiot and told to hire an electrician. Luckily with a like help here I fixed it.Anything that can give us a look at the actual signal should be helpful.
A graphical multimeter might be an affordable choice.
Once you get a look at the signal, you can do things to try to affect the signal by turning things on or off or disconnecting or putting a tone on the line to create noise that will affect the signal on the meter.
Hopefully, you will be able to isolate the leaking wire by watching for some sort of change in the visible signal when you do something on the line.
Awesome thanks!Anything that can give us a look at the actual signal should be helpful.
Agreed! Nothing but respect and genuine helpfulness. It's very welcoming and has made a lasting impression; this community is first classI just wanted to give kudos to this group for helping. I was having issues wiring a GFI and a timer and asked on an electrician forum and was pretty much called an idiot and told to hire an electrician. Luckily with a like help here I fixed it.
I am following because stuff like this interest my engineering brain
I’m here solely *for* said community. My pool took care of itself and I learned the chemistry (here) for fun years later.this community is first class
