I've replaced the shaft seal assembly numerous times, replaced O rings, even replaced the impeller. Yesterday along with a new shaft seal I even installed a new "rear seal plate" and no matter what I do I can't get the shaft leak to stop completely. It's better but still dripping. I don't have access to a runout gauge but the motor shaft isn't damaged and turns smoothly. The motor runs quite with no odd vibration. I'm really at my wits end and it's a real PITA to remove the pump and do this job over and over. Any help or ideas would be appreciated. --- Thank you!
The pump is a STA-RITE MPRA6E-147L
The motor is an after market B2982T (AOS-SPC-B2982T) - Pool Motor Square Flange 1 HP Full Rate Dual Speed w/ Digital Controller (B2982T). This motor is quiet and in its 5th season.
