So a few days ago I tested my water and there was ZERO chlorine measured. The salt cell was saying the salt level was too low. I even tried adding salt to bump it up but it did nothing. I took the cell and a water sample to my local shop to verify what was really going on. Turns out, as I suspected, the salt cell was bad and giving a faulty reading.
So I first tried cleaning the cell. Plugged it back in after and no change. My pH was high (7.8) so I dumped the acid water mixture I used to clean the cell into the pool. Not sure if that's relevant or not, but figured I'd mention it.
The cell seemed a bust so I ordered a new cell. While I waited I added a few gallons of bleach to the pool to hopefully get SOME chlorine back in there. I wasn't sure how much to add since I typically don't have to. I measured the next day and it still showed zero... so I guess it was't enough. The pH was 7.4.
All this time, the water seemed fine. It was clear to the bottom and didn't smell weird or anything.
Yesterday afternoon I got the new cell and installed it. I set it to super chlorinate and took out the shutoff timer so the filter and cell would run overnight.
This morning I had a look and I'm seeing green residue on the steps and the upper part of the vinyl at the deep end. It's not terrible, but it is visible. Looks like I didn't fix it in time after all. I took a measurement and I got a 6.5 TC, 0.5 CC, and back up to 7.6ish pH. I left it running like that for today and will check it again after work.
Did I do anything wrong (other than letting it run as long as I did with a bad cell)? Is there anything I should do now to clean this up or keep it from getting worse? Am I going to have to vacuum this stuff out?
Thanks in advance for any help. I'm still pretty new at this.
