ScreenLogic connection when not at home
dbettinelli
1
85142
I would like to connect to my pool equipment when I am not at home using my Screenlogic App when I am not at home but cannot seem to find out how I set that up. When I am on my wifi at home everything works great but I would like to control some things when I am not at home. Any help would be great.
Jimrahbe
19,493
Bedford, TX
D,
Not sure what the problem is.. If your WiFi is on the phone will say "Connect to Local Adapter".. When the WiFi is off the phone will say "Connect to remote adapter." In both cases it will display an adapter name, that you just need to select..
What do you see when you do this??
ncbart
15
TX
D,
You have to manually type in the adapter name the first time you connect remotely. After that, you can select it from the list when connecting remotely. I suspect this is the issue - the adapter name isn't automatically showing up remotely.
kazamali
45
Austin, TX
On that same note, my PB said to NOT set a password for the Screenlogic because it was impossible to recover if lost. Is that true? It's interesting because whenever I'm at a neighbor's house, with a pool, It's funny to pull up my app (while I'm on their wifi) and see what they have. I'm not being nefarious, but just like with any Smart appliance, I'd prefer to lock it down.....
spanman
14
Phoenix, AZ
I use the iPhone version of Screenlogic Connect. When connecting remotely the first time, I have to type "Pentair:" before the 6 character address (without quotation marks). It should look like this: Pentair: xx-yy-zz
