hey all, hoping someone can help.
i have recently started to measure and record my sand filter PSI to know when to backwash. i have a 2 stage pump with a low and a high setting, i usually run the pump for 7 hours per day on the low setting and only use the high setting for vacuuming. looking a my pressure gauge today it reads 0 PSI on the low setting and 15 PSI on the high setting. is this a fault with the gauge? surely even the low setting should have a reading. with the pump on the low setting there is clearly water coming from the returns, so there is definitely flow and i haven't noticed the flow to be less then normal. any suggestions or help appreciated. thanks.
