Sand Filter - Backwash & Rinsing Low Pressure
Sep 8, 2009
11
#1
I inherited an inground pool when I bought the house 3 years ago and everything worked okay even though it has pretty dated equipment like a Jacuzzi Laser 225 sand filter and an old Hayward Superpump. Due to various personal reasons, I only got to open my inground pool this past weekend. I was glad that it was not a green mess but it was dirty inside - probably due to the powerwashing of the deck a few weeks ago.
Anyway, I connected everything, started it up and vacuumed the pool. When the psi increased, I tried backwashing it and for some reason, only a small flow of water flowed out (the water in the sight glass hardly moved at all). I tried switching it to drain and the same thing happened. When set it to rinse, it also appeared to be on low pressure. However, when I switch it back to filter, it works fine.
My initial conclusion is that the sand could be old and clogged where the backwash/drain pipe is, so I am thinking of replacing the sand as I suspect the sand has never been changed for decades. Let me know if I'm on the right track or if there is something else I should check before replacing the sand because it is going to be the pain to disconnect the pipes seeing the way they have been connected to the sand filter.
linen
8,649
Twin Cities, MN
#2
Sounds like a valve problem. When on backwash,drain or rinse, can you feel any flow going back into the pool at the return?
RobbieH
4,052
Dallas, TX
#3
I don't know what you consider dated equipment, but my pool was built in the 50's and most the equipment put in between 1989 and 1991. With a sand filter, as long as you don't have sand blowing into the pool at the returns, you should be good!
You don't need to change sand in most cases, although there are a few rare reasons to do so. You may have channeling going on, or you may simply need to remove the top of the filter and rinse out the sand. Have you checked these yet?
Also, Linen has some good advice for you to check too.
Sep 8, 2009
11
#4
Thanks for the messages. I checked if there was any flow at the return while backwashing, draining or rinsing, and the answer and no.
I did not have time to remove the sand filter valve to check yet but will report back shortly when I do. I'm a total rookie with this, so what should I be looking out for? I've looked at the user manual and it does not provide any detailed drawings on the valve at all.
duraleigh
Admin
Platinum Supporter
In The Industry
Apr 1, 2007
31,273
#5
Check the multiport valve. If it was working when you were filtering and then stopped working when you switched to backwash, the only thing that changes is the position of the multiport. You will have to disassemble it but it's innards are pretty straightforward to figure out if there is a problem or not.
Sep 8, 2009
11
#7
Thanks for all the suggestions, they are really helpful. Hopefully it is as simple as a plug in the backwash line, then I don't have to remove all the lines to check the valve. The last time I removed one of the pipes to change a connector, it caused leaks that took me longer than expected to stem.
I wasn't aware that the rinse cycle use the backwash line as well?
I'll have to find time one of these evenings to troubleshoot. Luckily, the filter cycle still works and I don't have to deal with a green pool.
Sep 8, 2009
11
#8
Success! It was a plug in the backwash line afterall, thanks to all for your inputs. Now, on to my next problem, a leak coming from my pump which I will start another thread if I can't resolve.
