Same green start to season
TerriP
67
Marengo/IL
Hi all! Uncovered my pool I. May and it was almost clear but lots of leaves at the bottom. Winter cover had a rip in it.
Filled to skimmer level and began to filter. Life got in the way and a week without attending to pool equals a greenish brown mess. There are so many little seeds, tree flower buds, and cottony stuff from surrounding trees that I could skim for hours.
I started the SLAM yesterday morning, keeping the FC at 20, CYA is 50, pH is High at 8.2. Ive brushed, vaccuumed, cleaned filter cartridge 3 times a day and barely seeing progress in pool. I have one more free day to focus on the pool before I have to go back to work which means attending to pool early am and after 6:00 pm.
Am I missing anything? Should I just keep the faith and continue the battle?
picture is before I started to SLAM
28’ rd AGP, cartridge filter. 1.5 hp
mknauss
44,895
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
Cleaning out any solid debris is job one. That will delay the transition to cloudy blue.
Did you test the pH prior to raising your FC? The pH above 10 ppm FC is not a reliable data point.
TerriP
67
Marengo/IL
I’ve vaccuumed twice today and will do a third time. I also am using the leaf skimmer to lift out anything I can.
No I did not test the pH before SLAM 🙁
mknauss
44,895
Laughlin, NV
Fiberglass
If your FC is close to 10 ppm at one of your tests, test pH. Then add acid to lower to 7.2.
You need TA at that time for how much acid to use.
Any chance someone could add some chlorine mid day?
mknauss
44,895
Laughlin, NV
Fiberglass
Then based on what you have been adding each time, have them add the same amount of liquid chlorine. As long as you get even close to SLAM level FC, it will help. With how your water looks, doing it two or three times during the day would even be better.
TerriP
67
Marengo/IL
FC has been holding pretty well. Last night at dusk is was at 20. 7:30 am it was at 16. Throughout the day today it only dropped to 18. It is a bit clearer now as I can sew the brush a bit farther into the water. Here’s hoping for tomorrow.
mknauss
44,895
Laughlin, NV
Fiberglass
OK -- much better than the picture you posted. Still have someone add 5 ppm FC worth of liquid chlorine mid day and see what it looks like when you get home in the evening.
TerriP
67
Marengo/IL
FC dropped to 7.5 overnight. I will lower pH and continue manual cleaning, brushing then Slam again at lower pH.
mknauss
44,895
Laughlin, NV
Fiberglass
If you want to test pH during a slam you can neutralize the chlorine by add a few drops (and swirl) of thiosulfate prior to running the pH test. Thiosulfate is the first reagent in the total alkalinity test, R-0007.
Sorry - but that will change the pH result. Do not do that.
TerriP
67
Marengo/IL
Is CYA reading accurate during SLAM? Last time FC was at 10, I tested pH and lowered to 7.2, CYA was at 50. I’ve been SLAMming for 7 days since then along with vacuuming, brushing and rinsing cartridge. Typically adding 32-64 oz to bring FC back to 20. There is improvement each day but a slow process.
I’m going to carry on and hope for clear water soon.
When the pool passes the overnight test, I will test everything.
What is the order to address chemicals?
mknauss
44,895
Laughlin, NV
Fiberglass
Reactions: TerriP
