Greetings. I am new to the forum, and new to the world of spa and pool ownership (about 3 weeks or so in on the pool, a week on the tub). TFP has been a godsend and I have had great success balancing and running my pool and tub. The app tells me what I need to do, I do it, and the results show. Now, I am starting to look for the "easy button" on the hot tub.
My hot tub is 425 gallons, and I am using a Saltron mini to help manage the chlorine. I've been testing multiple times per day to get a handle on what happens after use and how to bring it back in balance, etc. I have read the chemical guide on TFP How do I use Chlorine in my Spa (or pool)?. At this point, I am working toward a routine, and hope that someone here has one down that might serve as a rough guide for me.
My thought process is that I can figure out how many hours per day of run-time of the Saltron will MAINTAIN a given level of chlorine, then after use, I should ADD the estimated amount of free chlorine that I used up. The guide that I mentioned above indicates that you might expect to use 7ppm/hour per person in the tub (less gallons than mine as I recall). And that seems to be fairly accurate for what I am seeing. How many hours per day should I start at to maintain my chlorine level?
Is it reasonable to think that I can test the tub just before I can get in, dump in an estimate of bleach when I get out, drop the mini in, and be ready to go the next day? If I use the tub every day, is it reasonable to think I could get out of the tub, drop in the Saltron (set to a higher number of hours), and have the Saltron bring the FC back to where it needs to be for the next day and NOT add bleach when exiting? THAT would be super easy.
What are your best ideas for managing a tub using the Saltron? I am eager to hear your ideas TFP!
Thanks!
Thanks!
