Salt water pool - lower alkalinity and higher chlorine
kenpee
18
Florida
New pool owner. Hot weather in S FL And pool is usually around 90. Have a salt water generator. My salt water generator is set to 60.
im new to testing as well but I have strips and a dpd kit.
Seems like Alkalinity is around 80 but free chlorine is high. Cyuranic acid seems fine. Combined chlorine seems 0.
How should I try to lower the free chlorine?
Texas Splash
40,599
Fiberglass
CircuPool RJ-45 Plus
Free chlorine will lower on its own, so there's no need to make it fall. The biggest concern is that you don't seem to have a TF-100 or Taylor K-2006 test kit. We know strips are horrible, and if you only have a DPD kit you're missing out on badly needed accuracy. I would recommend obtaining one of those kits and posting a full set of results. With accurate results, we can certainly guide you better.
kenpee
18
Florida
I have the Taylor Technologies K-1004-1 Test Kit Residential Trouble-Shooter DPD. Does that lack a particularly important test That the TF-100 covers? Thanks
kenpee
18
Florida
Hello,
I've been trying to learn how to properly test my pool but I've been struggling a bit. Here's a step by step walk through of what I've done and the results.
Test kits:
1. Aquachek 7 Strip:
  • Total Alkalinity looked a little low to me. It matched best with the color for 40.
2. Aquacheck Salt (Sodium Chloride) strip:
  • I think this lined up best with 1,920ppm, but I'm not positive.
  • Would 1,920ppm be low?
    • If that's low, should I turn my SWG higher?
3. Aquachek Free Chlorine strip:
  • Total Alkalinity seemed to line up best with 40, which would be on the low side.
    • If so, should I turn my SWG higher?
  • PH appears to line up best with 6.8, which would be on the low side.
    • If so, what should I do about this?
4. Taylor 6 Way: Free Chlorine and Total Bromine:
  • Free Chlorine didn't appear to match any to my eyes, so it may be too high.
    • What should I do?
  • Bromine didn't appear to match any to my eyes, so it may be too high.
    • What should I do?
5. Taylor 6 Way: Total Chlorine:
  • Total Chlorine also didn't appear to match any colors to my eyes.
    • What should I do?
6. Taylor 6 Way: pH:
  • pH appears to line up with 8.2.
    • Is this high?
    • What should I do?
7. Taylor 6 Way: Total Alkalinity:
  • It turned from green to purple after 8 drops.
  • So that means 80ppm, which sounds like it's on the low end.
    • What should I do?
Thanks for any help in advance. I'm not sure if I'm misreading results, have poor test kits, or what. My SWG was installed about a month ago. I haven't used any other chemicals. I did just start to notice some algae in a few spots above the water line in the grout:
mknauss
51,246
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
The combined thread shows you are trying to use a pieced together set of test kits.
The strips are trash. Throw them away. We will not provide guidance based on them.
You need a FAS-DPD test for FC/CC testing.
Your TA of 80 ppm is fine.
Lower your pH to 7.6. The TC is above 5 ppm. But most likely not above 10 ppm. You need a proper test kit.
kenpee
18
Florida
Can you please just recommend me a solid kit? Don’t really care about cost. Just want to buy and use one that folks like yourself find to be suitable so I don’t keep wasting money trying to guess and piece some together. Thanks!
mknauss
51,246
Laughlin, NV
Fiberglass
I suggest the TF-100 / TFPro or Taylor K2006C. A proper test kit is needed to get the accurate water chemistry results needed to follow the TFP protocols.
The TFPro Salt from TFTestkits.net is your best value. It will include a SmartStir and the salinity test kit. In Florida, you need the salinity test kit.
