Salt Level Instabilities Questions
Jedisparky
139
L.A. CA
Pentair Intellichlor IC-40
Hello Friends,
I have read a couple Fourm discussions and want to confirm what I think I have read. Yesterday my pool temp was 70 degrees Fahrenheit and my salt levels were 2000 steady after 3 tests. We've had some heavy rains this season and I haven't added any salt for a couple years. The reading dosen't seem out of line. So I added 5 40lbs bags of salt. 4 hours later I did a salt check (I know 24 hrs is going to be more accurate, just checked for the heck of it) and got a 3200 reading. I left the pump running all night and did a test in the morning. My reading is now 1700. Hmmm. Ok, so now the water temp is 65 degrees. Seems from what I'm reading that this will affect my salt readings. But THAT much? Obviously I won't add any more salt, and just wait till it gets warmer to achieve a more accurate salt result. Just wanna see if the group think concurs with my assessment or see if I'm missing something.
Thanks
mknauss
37,042
Laughlin, NV
Fiberglass
Water temperature will not effect the K1766 salt test. I assume that is what you are using?
Jedisparky
139
L.A. CA
I'm using the Taylor K-2006 Complete (FAS-DPD chlorine) Kit. It's what I learned on so I'm comfortable with it.
mknauss
37,042
Laughlin, NV
Fiberglass
Great.
How did you test the salt level?
JamesW
23,936
Are you talking about the reading from the system or your salt test kit?
What does the salt reading from the system say?
Does the Intellichlor show good salt?
What test kit do you have?
This is the kit that you need.
JamesW
23,936
Are you doing the test correctly?
Using the correct amount of water and using the correct multiplier?
Jedisparky
139
L.A. CA
Ok, thank you guys! It's early, I haven't had coffee yet. It just took me typing my testing steps down for you to realize I forgot to multiply the the drops by two. 17x2=3400. Doh, much better. Thank you as always for your time and patience. I'm going to stick my head in the pool now, lol.
Mike
